Tesla tyre guide: pressure, rotation and replacement (Model 3, Y, S, X)
Teslas are heavy and have instant torque, so tyres often wear faster than owners expect. Here's how to make them last.
Pressure
Use the pressure on the placard on the driver's door pillar, checked when the tyres are cold. The car shows live tyre pressures on the screen.
Rotation
Tesla's maintenance schedule recommends rotating your tyres regularly (around every 10,000 km / 6,250 miles), or sooner if the tread depth differs noticeably between tyres. Check your owner's manual for your model.
Alignment
Get it checked if the car pulls to one side or the inner edges of the tyres wear faster than the rest.
Replacement
  • Stick to the same size and load rating as the originals.
  • EV-specific tyres can help with range and road noise.
  • After fitting new tyres or rotating them, update the setting in the car (Service > Wheel & Tire Configuration).
Your turn: how many km or miles did your first set of tyres last, and what did you replace them with?
Back
Top
