Tesla home charging guide: Wall Connector vs Mobile Connector vs a regular socket
Thinking about how to charge your Tesla at home? Here are the three main options and who each one suits.
1. Regular household socket
The slowest option, adding only a few km of range per hour. Fine if you drive very little each day, and handy as a backup.
2. Mobile Connector on a dedicated higher-power outlet
A good middle ground for moderate daily driving, and a common choice for renters who can't hardwire anything.
3. Wall Connector (hardwired)
The fastest way to charge at home and the most convenient for most owners with a driveway or garage.
Before you buy
  • Ask a licensed electrician to check your panel capacity and install a dedicated circuit.
  • Check for local rebates or incentives on home chargers and installation.
  • Charging speed depends on your local voltage, the circuit and your car's onboard charger, so check your model's specs.
  • Set scheduled charging in the car to use cheaper off-peak electricity.
Your turn: what setup do you use at home, and roughly what did installation cost where you live?
Back
Top
